Uppers and Lowers need replaced
#21
https://dodgeforum.com/forum/2nd-gen...ta-cc-4wd.html
#22
In one of my posts: "Purchased 2 MOOG during drive home and rented the "wedge removal tool"." (aka, pickle fork)
GREAT IDEA!
What an idiot, cutting the nut off is the same as removing it like you did on the passenger side. Use the wedge removal tool, you buthead!
That's the ticket! ~light bulb ignition~
Yup, I missed the obvious!
Thanks a ton y'all! Next time (if there ever is a next time), why use a dang hammer at all, cut off wheel was like cutting through butter. Then, use the dang pickle fork, ya dork, Robb!
Whew!!!!!
Whew!!!!!
#23
#24
I'm not sure how many people in this forum know this, but you really don't need a pickle fork to get the ball joint loose from the steering knuckle...... might be an old school way, but i learned to just hit the steering knuckle where the stud of the ball joint goes in, and after a few good smacks it pops right out....... my opinion is quicker than a pickle fork, i know i've popped them out with one or two hits with the hammer...... just don't miss, lol. same thing with tie-rod ends if you don't want to tear the rubber boot if your not changing the tie rod or ball joint, i know pickle forks are notorious for tearing the boots, just for future ref. i know it's a little late now, but might be a good piece of info. for somebody....... that $25 for a new tie rod because you tore the boot with a pickle fork might come handy for gas, or another part down the road.
#25
The seals do get useless when using the fork.
#26
yup, take the nut off like normal, then where the stud goes down in on the steering knuckle, hit the steering knuckle it's self, and the ball joint, or the tie rod will pop right out. works better on tie rods where you have more room to swing the hammer, but it saves the boot. don't hit the stud, but the part the stud goes into. nice and flat with a big hammer. give it a few smacks, and a tug with your hand to see if it's loose. saves the boot if your not gonna replace the part...... and putting it back together with a torn boot means your gonna be doing it again, but this time to fix either the tie rod, or the ball joint, lol. just an fyi for future work..... might save you a few bucks from renting a pickle fork.
