neutral saftey switch help
FSM should show the neutral switch...I believe it gets replaced by a clutch safety switch.
Also, the trans temp light runs through the PCM on the communications buss for the transmission. In addition to that light being on, you'll likely get a whole slew of P codes for improper RPM drop, open connection to convertor solenoid, open connection to overdrive solenoid, trans too hot, among others.
