Restored my headlights
So i was bored, Had this wild idea while in home depot, why not make my headlights look new?
Before Removal and refinish
Look at that lovely Haze.
So with reckless abandon I bought
600, 800, 1000 and 2000 grit sandpaper, sadly Home Depot didnt have 600 grit (WTF?) so I had go to O' Irish auto parts and get 600. Which was the same price as Home Depots but only had 5 sheets vs 10 from the ones at Home Depot.
3M Lens and hard Plastic Cleaner and a bottle of Lens Polish (I used this for the Parking light/ side marker)
1 can of clear gloss coat.
Also not avalible at Home depot is Adhesion promoter.
Not wanting to let the Drill feel lonely I opted to remove the lights vs doing it still mounted
So starting with a 5 gallon bucket of soapy water i cut my sandpaper into squares and let them soak for a few minutes. Im no expert at sanding so i went and wet sanded with all the grits.
I spent a good 30 minutes hand sanding with the 600grit on each headlight
Thats after the 600/800 Grit sanding
And after 1000/2000Grit
Now at this point im more excited than a 5 year old boy at Hooters, My arm feels like it too!
I now used a terry cloth and the 3m Lens/Plastic Cleaner as the last scrub stage, And wow what a difference
After this I clear coated them, I didnt use the Lens polish because of this, Now only time will tell how this goes/last
Sadly i didnt take pictures of the spraying Adhesion promoter and clear coat.
And the end result
Driver side before
And the end result
Driver side before
The following users liked this post:
V8Cowboy (09-12-2021)
on
Some wax them which helps a lot. You can also use one of many products out there with UV inhibitors made for plastic.
I use a 100% synthetic polish, marketed for Corvette owners that's approved for clearcoat, plastics and fiberglass. They advertise it's man-made formula has the highest UV resistance on the market. Pricey but it works.
I had rope lighting up high around my screened in patio/pool that the sun turned the plastic tubing so brown they were unusable after two years here in the Florida sun. When I replaced it a little over a year ago, I wiped the product on it with a cloth let it sit for about 30 mins then wiped it dry prior to putting it up. To this day, the rope lighting is as clear as the day I hung it. Which reminds me, it's probably time to take
out a ladder and hit it again...
But like i said only time will tell. Im hoping for at least a year. Im still hoping for covered parking but alas nada.
If it can keep rope lights from turning black and rough, im sold.
The wax method is next on my list if i start having problems with the yellow.
Trending Topics
I don't like the FIX system as they start looking bad again around 2 or 3 years. New headlights can be as low as $50 each and will last you 8 to 11 years no scrubbing, buffing, sanding or painting required and new don't look kind of distorted as the FIX never looks 100%.
How much did you spend on all that FIX stuff $30 or $40?
These are $85 a set that's $43 each http://www.ebay.com/itm/Dodge-97-04-Dakota-98-03-Durango-Crystal-Chrome-Clear-Headlights-Pair-Lamps-New-/321647445064?fits=Year%3A1999%7CModel%3ADakota&hash=item4ae3ae8448&vxp=mtr
These are $85 a set that's $43 each Dodge 97 04 Dakota 98 03 Durango Crystal Chrome Clear Headlights Pair Lamps New | eBay
I've never been one to temp Fix things if it needs replacing I replace the part. I understand at $50 or more each it sucks and is way over priced even on ebay for a plastic part that should cost about $25 I remember when the glass ones were around $15 not too long ago. I'm looking to buy these sometime in the next 3 months as my lights are just starting to get milky last replaced them in 06.
