Miss fire
Old 12-18-2015, 12:29 PM
Clark Bonnell's Avatar
Clark Bonnell
Clark Bonnell is offline
Default Miss fire
Question; p0302 p0303 codes, I replaced coil packs on #2 & 3 cylinders and replaced all spark plugs. 3 days later I am getting the same codes. Any ideas? This is on a 2001 Dakota.
Old 12-18-2015, 03:25 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
That's an injector circuit malfunction, and misfire code. Check the injector wiring..... also, ohm test the injector. No idea what you are driving, so, no clue what the value should be, compare it to a couple others... see what ya get.
Both of those codes relate to cylinder 3.
Old 12-18-2015, 09:43 PM
jkeaton is offline
Moved to the correct section.
Quick Reply: Miss fire
