Transmission interchange
Old 04-20-2017, 10:14 PM
frankie_b_jr's Avatar
frankie_b_jr
frankie_b_jr is offline
Originally Posted by dbbd1
Between the 5.2 and 5.9?
I thought its internal vs external balancing.
Those changes occurred from 95 to 96. Should be a direct swap.
Between 95 and 96 dodge moved the balance weights for the 5.9 from the torque converter to the flex plate.
Old 04-21-2017, 06:31 AM
prez-reaper13's Avatar
prez-reaper13
prez-reaper13 is offline
ok so i can use the torque converter and flex plate from the 5.2 with no problem bolting up to the 5.9 then
Old 04-21-2017, 08:43 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
If both trucks are 96 or newer, you need to use the flexplate for a 5.9 on the 5.9 engine. It is externally balanced, and the weights are on the flexplate.
Old 04-21-2017, 08:57 AM
prez-reaper13
yes mine is a 97 5.9 and donner truck is a 98 5.2 so no problems with torque convert just use the 5.9 flex plate
Old 04-21-2017, 09:24 AM
HeyYou is offline
Correct.
Old 04-21-2017, 09:40 AM
prez-reaper13
awesome thanks for the info
Old 09-02-2017, 11:24 PM
David Wyman's Avatar
David Wyman
David Wyman is offline
Will a nv3500 from a 01 Dodge ram fit a 98 Dodge ram..both 1500 pickups with 4x4
Old 09-03-2017, 09:59 AM
HeyYou is offline
Yup. Bolt right in, hook right up.
Welcome to DF!
Old 11-17-2017, 08:26 PM
Robert Trubenbach's Avatar
Robert Trubenbach
Robert Trubenbach is offline
Default Tranny options
I have a 1997 Ram 1500 RWD with a 5.2. I will need to replace the transmission soon and want to know what I can swap in from another Dodge.
Old 11-17-2017, 10:59 PM
HeyYou is offline
You have a 46RE trans, so, pretty much any other 46RE from 96 to 99 trucks/vans (that are also RWD) should bolt right in, and hook right up. Doesn't matter which engine it is behind. (5.2 or 5.9, but, NOT the 3.9)
Quick Reply: Transmission interchange
