MY continuing sage re A/C
yep, 2.5, yes, I vacuumed the system down to 28-30 it held for an hour then I charged with two cans of 134 the first can went all in the second can about half maybe a little less. I have a gauge set and can hook it up again and add some more 134..but w/o hot wiring the compressor to turn it on it wasn't turning on so getting more 134 in wasn't happening..So I stopped and that's why I am trying to pin down what is keeping the compressor from kicking in..
OK I'll give it a try I was just afraid to hotwire the compressor. I watched several utube videos on the process and in each the compressor kicked on after most of the first can 12 to 16 oz. was sucked in by the vacuum alone. But like I said mine took the whole 12 oz. can but never kicked on..didn't seem right...
I jumped the compresser stillissues
I tried again..I tested the line from the dash board..took the connector off at the compressor, started her up, turned on teh A/C and the fan and put a meter on the open connector..positive to the open connector and the negative to ground..read no volts so the switch in the dash is not sending to the compressor don't know if it's because the sensor on orifice tube is bad or if the is an open wire, connection etc. between the switch and the connector. So I decided to hotwire the compressor to see if that would suck more 134 in and get it working. So I purge the lines of the gauges, hooked up another can of 134 hooked it up, purged the yellow line, opened the gauges and then the low and high side valves on the system..turned the engine on and hotwired the compressor..both the high and low side went to 100. I let the can empty so now I have put in 1.8 lbs which is the recommended amount probably a little less due to purging etc.
I still have too high pressure on the low side..I am stumped..new compressor, new orifice tube with new filter inside, new dryer, new condenser. What could be causing this???? besides a bad compressor??? which is brand new...
update
sorry to say I gave up and took it to a garage..a blown fuse not sure how I missed that..they charged her up works fine...the guy said the pressure high on both side may have been just not letting the compressor run long enough to balance the pressures out..but I said I let it run 3 or 4minutes and it still stay high on both sides..and in all the utube videos the pressure low side dropped within a minute of adding 134..he just shrugged his shoulders.. he must have been correct as all they did was replace the fuse, vacuum the system and charge it up..according to the invoice.
