The project Dakota
Old 10-16-2017, 02:23 PM
Liam Hammontree's Avatar
Liam Hammontree
Liam Hammontree is offline
https://youtu.be/I9YMO8B4Cyw
  #22
Old 10-16-2017, 02:24 PM
Liam Hammontree
Originally I thought there was more damage to the trans which is why got it for what I did. Gave myself $900 cushion in case it was gernaded.
  #23
Old 02-17-2018, 08:19 PM
LeaningDAK's Avatar
LeaningDAK
LeaningDAK is offline
Default Update: she's coming together
I've finally found a torsion bar and had it shipped. The original was bent in such a way that even with the entire drivers front suspension disassembled it would not budge. So after a few minutes with an angle grinder I was able to remove the bent TB. Now I cant seem to get the lower control arm to go back in to place with the new torsion bar inserted..... It's the metal insert on the bushing that is hitting the mount on the frame. I don't have the strength to move it any farther back and can't remove the front bolt on the LCA because the sway bar is in the way (seems the bolt was installed backwards Imo) any ideas?
parts replaced and total cost so far:
CV axle. $54.03
Inner tie rod .
Outer tie rod
Upper ball joint. $47.00 for ball joints, tie rods,etc
Torsion bar. $60.00
Hub assembly . $31.37
Brake rotor .$27.00
Struts. $35.55
front plastic bumper $50.00
Rear of LCA
Progress
^^^^^^^Thats what happens when you try to rush things fyi I couldn't access my original account. I am the OP.
