Starter going bad?
Don't get mad but its actually on a 99 blazer that im working on but its a starter and every vehicle has one and this forum is more active. I was leaning more towards rebuilding because it's cheaper. I don't have a warrenty on it because I didn't buy it. And i can't take it anywhere because I don't have a trailer and it won't turn over enough to fire up because of the starter. I have googled and searched for anything that resembles what this one is doing but all i find is either it does nothing or clicks. This one actually turns the engine over about twice then gives up. I appreciate the help
Sounds like a bad bendix to me. You might be better off just biting the bullet and replacing it. But if you can find a starter/alternator shop nearby, that would be my next move. Depending on the year, the GM is probably also a nippendenso. They are very popular OEM starter/solenoid combinations, only thing different is their mounting bosses.
This is what the starter is doing. I took the starter out and took the starter apart and everything in the starter looked fine. I put it back together and back on and it does the same thing. I didn't take the solenoid apart so I'm guessing that it's the problem. I checked the voltage on the small wire and it gets battery voltage (12.6x volts) with the key at start. I'm going to try to get a junkyard starter tomorrow if i can find a place open and see what happens. With my luck I'll get one with a bad solenoid and still be in the same boat.
it is a driveworks from advance. I knew there was a reason i never go there lol. I'd rather go to one of the other 2 and have them price match for their store brand if it's something i really need and don't have much cash.
Every parts store has it's 'cheap' brand, and while the name may change, they likely come from the same facility...... I have had brand new parts from autozone fail within a couple days...... I have had parts from just about all of them be bad right out of the box. (including rock auto.) Its more what brand you are buying, than what store you are buying it from. Another guy went thru four 'rebuilt' starters, until he finally elected to spend the case on a NEW one, and that solved his issues.
