2.5 engine rebuild project
Old 03-29-2018, 02:22 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Talking 2.5 engine rebuild project
New .040 over pistons mild Comp Cams upgrade cam, new ported Head with stainless steel over sized intake and exhaust valves. A quality engine balancing will be preformed most parts will be new.
Pic’s will be posted as I work on her I have a few of a ported intake I created and a few others I did last year ahead of the R/R like the head.
Start Date for the 100% rebuild is 8th of April.
0
0
0
0
0
0
Old 03-29-2018, 05:28 PM
Skreelink's Avatar
Skreelink
Skreelink is offline
Everything is so pretty and clean, good luck on the build. I wish I could get a chance to drive a 2.5L... My brother's a mechanic and has had the chance, he says they're pretty peppy and fun. Got a picture of the truck itself?
Old 03-29-2018, 06:54 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Well she is getting beat up now that the paint died but this is her this pic is a year back I have modified her considerably in many ways.
Old 03-29-2018, 07:17 PM
Skreelink's Avatar
Skreelink
The engine bay is quite colourful in that picture... wow, and the belt routing is odd. Gonna have to get an emblem for that hood, but looking good. Sadly, the previous owner repainted the truck (had a bit of a front-end foray, they fixed the damage, but I noted the damage to the A/C condenser and cut in the overflow bottle from the bumper mount) and put red on with no clear coat, so my truck isn't all shiny. It was black from the factory, which I would have preferred, but ah well. I notice the contours on the tail lights... Altezza style?
Old 03-29-2018, 07:42 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
I am the original owner new off the lot no front damage I just didn't like the pealing paint so flat black was it. The belt original no change she is a Canadian built Dakota. Front rad and all A/C was changed out for a 2000 model setup all better setup. As I said I made many changes the past 7 years.
Old 03-29-2018, 07:54 PM
Skreelink's Avatar
Skreelink
Ehhh, I meant repainted the truck I own before I bought it. Yey typos. And yeah, I understand about the peeling paint, this is my first venture into Chrysler/Dodge, but everything I've heard is they aren't all that great on the whole resilient paint thing. Everyone I know that owns an older dodge or chrysler product has worn clearcoat/other paint issues. The previous owner also rattle-can'd the rims (same as yours) black :/ it's peeling and whatnot so I'm on the lookout for some clean ones (nowhere around here that'll refinish them and can't really afford it at the moment anyway). Keep up the posts and images.
Old 03-29-2018, 07:58 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Old 03-31-2018, 01:14 AM
magnethead's Avatar
magnethead
magnethead is offline
Sheet metal screws right through the AC condensor? How's that work?
Old 03-31-2018, 06:01 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
No they are bolts a nut is on the other side with a plate its a solid good condenser by 4 seasons their top of line model. I found out later I could have used a Durango condenser that was about 20% bigger and fit like stock as they use the same radiator and mounting points as a same year Dakota HOT AZ you need all the cooling help you can get.
This one I picked as it was the largest in size Rock auto had.
It looks wrong but is very solid in construction 2 years no problems I think the bolts are solid through the core and clamps the core well.
These flat serpentine type condensers they started using in 2000 are built like a radiator very thick and don't puncture like the older round tube condensers. This was part of the change to r134a the serpentine type condensers cool the hot r134a more efficiently.
Types of condensers oldest left round tube newest is on the right side.
This is my original 1998 round tube condenser.
Old 04-01-2018, 10:11 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Lightbulb
If anyone is interested the NEW yes NEW head I purchased here.
https://www.quadratec.com/products/5...FZSGfgodp4wLFw
Quick Reply: 2.5 engine rebuild project
