realy it isnt bad, however i have a lift and a tranny stand, on the ground you can do it...but its reaaaly okward...have a friend help ya remove bolts etc. pull off..
My problem is removing the exhaust it is stuck I also have to remove the transfers case along with two drive shafts... so so much fun heh. I will give it a try today.
I have tried and tried to remove the transfer case, it seems very hard geez they should make these things a bit easier to pull out. Does anyone have a step by step guide with pictures of each step? It is always easy to explain but pictures are much better.
