mahowaldjl |
04-13-2009 08:38 PM |
Freddy - it sounds like you have the NV 144 transfer case. The 4 lock position locks the transfer case so the front and rear drive axles rotate at the same speed. There are still open differentials in the front and back, but this helps improve traction for loose or slippery surfaces. The NV 244 transfer case has a 4 lo position which provides the same locking function as the 4 lock, but a low gear range for when a high torque at low speed is needed. The people I have talked to that have this don't use it. Unless you plan on climbing steep hills or pulling a dock out of a lake, you probably do not need it. 4 Lo will not do much to keep from getting stuck.
