Cranks but won't fire
I have a 98 with 2.7. Drove car home shut off and ran in house for less then 5 minutes. Car will only turn over. I smell no fuel when cranking.
Things checked so far 1. Check all fuses and relays - good 2. Pulled fuel tank cleaned filter and checked pump by hooking it up to marine battery and it seems to pump fine. Tried forcing fuel up the fuel rail with the marine battery powering the pump with no luck. 3. Checked to make sure power was getting to pump by disconecting wire harness under rear seat - good 4. Sprayed starting fluid in throttle body and car will attempt to start. |
Need to pull the codes and tell us what they are please.
I hope you checked the fuses and relays under the hood as well as in the car.
| All times are GMT -4. The time now is 01:36 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
