DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Intrepid (https://dodgeforum.com/forum/2nd-gen-intrepid-92/)
-   -   Wet driver's side floor board (https://dodgeforum.com/forum/2nd-gen-intrepid/249558-wet-drivers-side-floor-board.html)
krf2876 Jun 16, 2010 09:16 AM
My 2002 Dodge Intrepid has a coolant leak somewhere and now the floor board on the drivers side is soaked. I've been told by some that it could be the heater core that is leaking. Is this possible? If so, does anyone know the approximate cost for replacing the heater core? Help!!
Altair Jun 19, 2010 01:47 PM
Welcome to DF krf2876!
I'm moving this to the 2nd gen Intrepid section for you, you'll get more help here.
kurts2 Jun 21, 2010 12:17 AM
Well, if you don't want heat you can bypass it for less then $10. To fox it yourself you will still need to have someone vac and service your ac. This plus the removal of the dash will cost you hundreds but if you do all of it except the ac it will run about $100.
© 2026 MH Sub I, LLC dba Internet Brands
