1998 Intrepid interior lights stay on
I have a 1998 Dodge Intrepid and the interior lights stay on. Usually they automatically turn off. The switch is not in the on position either. Is there any other thing I can check? Right now I have to pull out the fuse to turn them off.
RE: 1998 Intrepid interior lights stay on
It sounds like your door latches aren't closing properly, just check to see if all the connection points on all 4 doors are clean and touching each other. Each door has 2 connect spots to tell the computer that the door is closed, if the car thinks that any of the doors are still open the lights will never turn off. the contacts are just 2 circular dots of metal you'll see them on the door hinge closest to the front of the car.
Chris |
