Question about transmission
This might be really dumb to as but is it even possible to put a automatic transmission with a shiftronic in a neon? Just curious.
RE: Question about transmission
Its physically possible, since the PT Cruiser uses the same 4-speed automatic transmission as the Neon only with the AutoStick feature added. The problem would be with the Neons PCM...you would proably need the PCM out of the auto PT Cruiser, in which case, you would need to compelely change the enigne and all the wiring as well...
Or you could go and buy a RMVB (reverse manual valve body) which lets you shift the transmission manually...basically turning it into an Autostick. |
So pretty much I would have to go buy the engine and transmission from the PT Cruiser and drop it in my car to have the shiftronic in it?
If you want the true Autostick you would basically have to do a complete PT Cruiser swap into a Neon body.
How hard would it be to do that and what would I need? lol, I think having that stick would be freaking awesome. :D
Then I had another question, does it matter what year you pull the engine and all from the PT Cruiser? Like if I went and yanked one froma 05' would it work in my 01' neon?
No, it wont really matter but you'll need to get the entire wiring harness, that would also include the dash harness as well since Neon electronics wiring isnt compatable with PT Cruiser electrical stuff.
