Evaporation Control Solenoid
My wife has a 2003 dodge neon that is showing a P0441 code. I think that the purge solenoid has gone bad. Can some one please inform me of where this is located at under the hood? A diagram would be great if anyone has one.
Thanks |
RE: Evaporation Control Solenoid
I have the same problem.....2003 Dodge Neon SXT. Code P0441, I have tried to reset it, and it would go away but come back about every 3 or 4 months. Now it is coming on about every 2 or 3 days.....Please help with us with the location of the purge solenoid!!!!! Thanks :)
It's on the inside of the driver's side wheel well. Pretty low, just above the steering rack.
There are two vac lines running to it. One from the charchoal canister, another from the TB. Just follow the vac lines if you can't find it... |
Awesome....I found it. Now I just have to make sure that one of the vacuum lines isn't bad. Could there be anything else causing this problem? Possibly a bad gas cap?
My wife has a 2003 Dodge Neon Sxt that is giving the P0455 Done! code. Replaced the gas cap and the check engine light came back on after 300 miles. Now what???
Leak Detection Pump Solenoid
