Blue Lights?
Hi My radio I bought and guages are all blue back light.. I wanted to make it all the same so I was wondering if theres a way to change the havoc controls and shift montior (P,D,N,R,1,2) blue also? Thanks I have a 2001 Neon
RE: Blue Lights?
You can make something. As for actually buying somethign pre-made I doubt it.
RE: Blue Lights?
I have seen the HVAC on ebay, not sure of quility or anything, but if you take the little plastic indicator off the shifter and bring it to a local sign shop they can make it out of clear plastic with blue lettering, or any other color scheme you want.
RE: Blue Lights?
Hi I wanted to get racing seats and four point harnesses in my neon (2001).. One thing i notice is that i think the seatbelt buckle part bolts right to the seat well if i switch the seats where will that part bolt then?
RE: Blue Lights?
Are you sure the belt bolts to the seat? I think it bolts to the center hump, I am not 100% positive, but take a better look.
RE: Blue Lights?
Okay thanks, in the meantime if anyone with a neon 2001 can check it'd be appeciated.. Im at my moms and i don't take my neon with me there...
RE: Blue Lights?
On my 04, the part where you buckle the seatbelt in is attached to the seat just like he's saying. Trust me because I've taken my seat out.
RE: Blue Lights?
he is rigth cause i just installed my racing seats and 4 point harnesses this past summer, but the seat belt light stays on though
RE: Blue Lights?
Take your cluster out and pull the bulb for the seat belt light if you want it to go away. You know the seatbelt will never be engaged so the dummy light is pointless.
RE: Blue Lights?
ORIGINAL: tom he is rigth cause i just installed my racing seats and 4 point harnesses this past summer, but the seat belt light stays on though |
