30a starter fuse blows
This fuse blows while ig. switch is in run position, not while cranking engine? Seems strange to me, any suggestions? Thanks for any help. |
RE: 30a starter fuse blows
Have you replaced the fuse more than once? If so i would get the starter tested and also use a volt meter to see if the starter is getting power when the key is at that stage. Might be a very bad ground too sence there is one connected to the starter. Hope that helps
