Need some help please
#41
cool
Yeah, I think I'll try the filter first because the pump sounds strong to me which I guess that doesn't alway's mean its not getting weak. Plus, like you said the filter and tool is way cheaper. By the way the car has 142,000 mi on it (about time for an over haul or maybe an SRT-4 engine) Ive only put about 1,000 mi on it since I got it back in November. Thanks alot, I'll let you know what happens.
#43
#44
#45
#46
Symptom List:
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER #1 MISFIRE
P0302-CYLINDER #2 MISFIRE
P0303-CYLINDER #3 MISFIRE
P0304-CYLINDER #4 MISFIRE
Test Note: All symptoms listed above are diagnosed using the same tests.
The title for the tests will be P0300-MULTIPLE CYLINDER MISFIRE.
When Monitored and Set Condition:
When Monitored: Any time the engine is running, and the Target Learning Coefficient has been successfully updated.
Set Condition: When more than a 1.0% misfire rate is measured during two trips.
POSSIBLE CAUSES
POSSIBLE CAUSES
- INTERMITTENT MISFIRE
- VISUAL AND PHYSICAL INSPECTION
- IGNITION WIRE
- ASD RELAY OUPUT CIRCUIT (COIL)
- ENGINE MECHANICAL PROBLEM
- IGNITION COIL
- COIL CONTROL CIRCUIT
- SPARK PLUG
- CHECKING FUEL PRESSURE
- FUEL PUMP INLET STRAINER PLUGGED
- RESTRICTED FUEL SUPPLY LINE
- FUEL PUMP MODULE
- CHECKING FUEL LEAK DOWN
- FUEL INJECTOR OPERATION
- ASD RELAY OUTPUT CIRCUIT (INJECTOR)
- FUEL INJECTOR
- INJECTOR CONTROL CIRCUIT
- PCM (IGNITION SYSTEM)
- PCM
#47
