2000 Dodge Neon code P1684 and P0171
My check enginle light just came on about a hour ago. I turn the key on and off twice. And these two numbers came up on the dashboard.
P1684 and P0171 Can anybody help by telling me with the two numbers mean for I don't have the book to show what these numbers mean.. Thank you |
Can't find the first one in the 03-05 manuals, but have the other one.
P0171-FUEL SYSTEM 1/1 LEAN When Monitored: With the engine running in closed loop mode, the ambient/battery temperature above (-7°C)20°F, altitude below 8500 ft and fuel level greater than 15%. Set Condition: If the PCM multiplies short term compensation by long term adaptive and a certain percentage is exceeded for two trips, a freeze frame is stored, the MIL illuminates and a trouble code is stored. POSSIBLE CAUSES GOOD TRIP EQUAL TO ZERO RESTRICTED FUEL SUPPLY LINE FUEL PUMP INLET STRAINER PLUGGED FUEL PUMP MODULE O2 SENSOR O2 SIGNAL CIRCUIT O2 RETURN CIRCUIT O2 SENSOR HEATER OPERATION THROTTLE POSITION SENSOR SWEEP MAP SENSOR OPERATION ECT SENSOR OPERATION ENGINE MECHANICAL PROBLEM FUEL CONTAMINATION/EXHAUST LEAK |
i couldnt find much on the P1684 code
but id did find on the internet that this is cause by the PCM loosing power at some point. Is your car acting funny at any time like loosing electrical power, misfiring, anything? Only thing i hate about new cars. Whatever happend to the good old style engines with carbs and distributors lol.. now everything has to have a *brain* to run. |
Haha, even the carbs can be a PITA though.
lol agreed
what code P 1684 means ...
P 1684 just means that you have disconnected the battery recently ...it wont have any effect on the way the car runs .
