SRT-4 Swap
Old 06-16-2009, 05:07 PM
Kabnoot's Avatar
Kabnoot
Kabnoot is offline
Default SRT-4 Swap
For a full swap how much am I lookin at?
Old 06-16-2009, 07:38 PM
Moparmatt440's Avatar
Moparmatt440
Moparmatt440 is offline
engine/trans, harness and pcm, depends on what kind of deals you find on the engine and trans. Once you get those everything bolts right in with minor modification, need to cut holes in your radiator support for the ic, the stock IC you can get for about $50 or so, engine/trans looking at maybe 3-4grand might be higher, some come with harness and pcm, then just need to get the motor mounts, not sure if the trans mount will cross over. So maybe 5gs if your looking to get a SRT motor and not a 2.4L to convert, that might be a bit cheaper, don't really know
Old 06-17-2009, 02:04 AM
djmagic's Avatar
djmagic
djmagic is offline
Matt i think the motor mounts are the same. Also if you do that it is also reccomended to do the srt-4 braking system as well.
Old 06-17-2009, 04:31 AM
Kabnoot's Avatar
Kabnoot
Kabnoot is offline
How much do you think I could find a wrecked SRT-4 for?
Old 06-17-2009, 10:56 AM
Captansavaho's Avatar
Captansavaho
Captansavaho is offline
search use it! this has been brought up so many times!
Old 06-17-2009, 06:02 PM
Kabnoot's Avatar
Kabnoot
Kabnoot is offline
And it will be brought up many more times. I am just trying to get some estimates. Try to see what people who have actually done it know.
Old 06-17-2009, 08:07 PM
Captansavaho
Old 06-17-2009, 11:02 PM
Kabnoot's Avatar
Kabnoot
Kabnoot is offline
My cars second gen. Will this be different then?
Old 06-18-2009, 01:02 AM
contagious19's Avatar
contagious19
contagious19 is offline
more room in a 2gn, i found a wrecked srt for 1500 almost bought but no money it all depends if u get lucky
Old 06-18-2009, 01:12 AM
Moparmatt440
huh I thought that the mounts for the 2.4 were a tad longer, I could be wrong, x2 on the upgrade to SRT brakes, the fronts are bigger then the stock regular neons, and the rear disc are just plan better lol, I did them on my sxt, stopping power is way better.
Quick Reply: SRT-4 Swap
