Input/output sensor 05 neon
I have a 2005 Dodge neon SXT automatic. The speedometer was jumping around. The car would shift gears sometimes, but not always. I replaced the output sensor and it worked flawlessly for about 5-10 minutes. Then the speedometer started to do the same thing again. However, It would not shift out of 2nd (I assume it put itself into limp mode). The speedometer was jumpy. Now, it will not move.
So could it be: 1) The output sensor went out again 2) The input speed sensor is also bad and needs to be replaced 3) Other Extra notes: P700 (looked into it further) -> p0501 a range performance -> brake switch a circuit high input -> Cruise control I am assuming (not relevant to issue) |
input sensor has nothing to do with your problem
could be bad connection on output speed sensor connector. I would be using a quality scanner and enter transmission Data info to actually diagnose the problem |
Originally Posted by 22mopar22
(Post 2593716)
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (AUTO TRANS)
When Monitored: Engine running. Transmission not in park or neutral. Brakes not applied. Engine run time greater than 10 seconds. Set Condition: The PCM does not see vehicle speed signal from the transmission control side of the PCM. Two Trip Fault. POSSIBLE CAUSES GOOD TRIP EQUAL TO ZERO TRANSMISSION DTC(S) PCM There is also this page: P0501 P0573-BRAKE SWITCH #1 CIRCUIT HIGH When Monitored: Ignition on. Set Condition: When the PCM recognizes Brake Switch is stuck in the high/off position. One Trip Fault. POSSIBLE CAUSES GOOD TRIP EQUAL TO ZERO BRAKE LAMP SWITCH OPERATION BRAKE SWITCH SIGNAL CIRCUIT OPEN GROUND CIRCUIT OPEN PCM However, since you messed with the sensor and it worked, first try checking the connector to make sure the wires are in there good, and then follow the wires as far as you can and make sure they aren't broken or grounded out. It's free and worst case, you are in the same boat you are now. :) |
Hi, I actually had that same freaking problem two weeks ago. I changed both of the sensors but it didn't fix the problem. Also, after changing the sensors, my car didn't want to start. So, I just checked all the wires going from the transmission module and sensors to the main computer with an electrical tester, and I found that one of the wires from the output speed sensor was broken inside the rubber, and I couldn't see it from outside, so I just cut the part that was broken inside and replaced with another wire. Now my car is running like NEW! well, you can try to do it.
