2003 neon engine code?
I am having a little problem with a 03 neon. I took it to the shop and got "transmission code 0841", says its a sensor cicuit. I was wondering if anyone had any info on this and if it's a serious problem or just minor. Thanks
RE: 2003 neon engine code?
Not sure what Year Neon this is information is for, but I am posting it from another website from
some mechanic in Virgina. I have a 2003 Neon with P0442 error code, which tells me its that darn evaporative problem again, just like the list show below, so it must be accurate: Ok, here's what you do: 1. Put the key in the ignition. 2. Turn key all the way forward - not to the point where the car starts, just to the point where all the lights come on. Do it in this sequence: ON-OFF-ON-OFF-ON.. 3. Keep a close eye on your odometer. You will see a series of codes display, followed by the word "donE"... 4. These codes will tell you why the "Check Engine Light" is coming on. Someone has a list on the web somewhere of what they mean. 5. Now, I'm going to make you a bet... I bet that the codes you see will be "P1684" followed by "P0456". These codes mean respectively: Bat. has been disconnected within the last 50 starts, EVAP sensor detection... 6. IF IT IS THESE SET OF CODES, fear not - nothing is wrong with your car. Simply... 6a. Tighten your gas cap, then... 7. Pop the hood, disconnect the NEGATIVE battery terminal - DO NOT DISCONNECT THE POSITIVE TERMINAL - FOR THE LOVE OF GOD. You will run the risk of shorting out the electrical system. 8. Wait a couple of minutes, then reconnect. 9. Start the car up and TADA! CEL is gone! P engine codes ( ie P0071 ) will appear on the odometer DTC's (Diagnostic Trouble Code) For 2nd Gen. (M) Check Engine Lamp (G) Generator Lamp Illuminated Generic Scan Tool Code DRB Scan Tool Display Description of Diagnostic Trouble Code P0071 Ambient Temp Sensor Performance Ambient change less than 3 degrees cel. In 200 miles P0106 (M) Barometric Pressure Out of Range MAP sensor input voltage out of an acceptable range detected during reading of barometric pressure at key on P0107 (M) MAP Sensor Voltage Too Low MAP sensor input below minimum acceptable voltage P0108 (M) MAP Sensor Voltage Too High MAP sensor input above maximum acceptable voltage P0111 (M) Intake Air Temp Sensor Performance Intake Air change less than 3 degrees cel. In 200 miles P0112 (M) Intake Air Temp Sensor Voltage Too Low Intake air (charge) temperature sensor input below the minimum acceptable voltage P0113 (M) Intake Air Temp Sensor Voltage Too High Intake air (charge) temperature sensor input above the maximum acceptable voltage P0116 Engine Coolant Temp Performance A rationality error has been detected in the coolant temp sensor P0117 (M) ECT Sensor Voltage Too Low Engine coolant temperture sensor input below the minimum acceptable voltage P0118 (M) ECT Sensor Voltage Too High Engine coolant temperture sensor input above the maximum acceptable voltage P0121 (M) TPS Voltage Does Not Agree With MAP TPS signal does not correlate to MAP sensor signal P0122 (M) Throttle Positon Sensor Voltage Low Throttle position sensor input below the minimum acceptable voltage range P0123 (M) Throttle Positon Sensor Voltage High Throttle position sensor input above the maximum acceptable voltage range P0125 (M) Engine Coolant Temp Not Reached Time to enter Closed Loop Operation (Fuel Control) is excessive P0130 (M) 1/1 O2 Sensor Heater Relay Circuit An opened or shorted condition detected in the ASD or CNG shutoff relay control ckt P0131 (M) 1/1 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range P0132 (M) 1/1 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range P0133 (M) 1/1 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency P0134 (M) 1/1 O2 Sensor Stays At Center Neither rich or lean condition is detected from the oxygen sensor input P0135 (M) 1/1 O2 Sensor Heater Failure Oxygen sensor heater element malfunction P0136 1/2 O2 Sensor Heater Relay Circuit An opened or shorted condition detected in the ASD or CNG shutoff relay control ckt P0137 (M) 1/2 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range P0138 (M) 1/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range P0139 (M) 1/2 O2 Sensor Slow Response Oxygen sensor response not as expected P0140 (M) 1/2 O2 Sensor Stays At Center Neither rich or lean condition is detected from the oxygen sensor P0141 (M) 1/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction P0143 1/3 O2 Sensor To Ground Oxygen sensor input voltage maintained below normal operating range P0144 1/3 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range P0145 1/3 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency P0146 1/3 O2 Sensor Stays At Center Neither rich or lean condition is detected from the oxygen sensor P0147 1/3 Os Sensor Heater Failure Oxygen sensor heater element malfunction P0151 (M) 2/1 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range P0152 (M) 2/1 O2 Sensor Shorted To Voltage Oxygen sensor input voltage sustained above normal operating range P0153 (M) 2/1 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency P0154 (M) 2/1 O2 Sensor Stays At Center Neither rich or lean condition is detected from the oxygen sensor P0155 (M) 2/1 O2 Sensor Heater Failure Oxygen sensor heater element malfunction P0157 (M) 2/2 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range P0158 (M) 2/2 O2 Sensor Shorted To Voltage Oxygen sensor maintained above normal operating range P0159 2/2 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency P0160 (M) 2/2 O2 Sensor Stays At Center Neither rich or lean condition is detected from the oxygen sensor P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction P0165 Starter Relay Control Circuit An opened or shorted condition detected in the starter relay control circuit P0171 (M) 1/1 Fuel System Lean A lean air/fuel mixture has been indicated by an abnormally rich correction factor P0172 (M) 1/1 Fuel System Rich A rich air/fuel mixture has been indicated by an abnormally lean correction factor P0174 (M) 2/1 Fuel System Lean A lean air/fuel mixture has been indicated by an abnormally rich correction factor P0175 (M) 2/1 Fuel System Rich A lean air/fuel mixture has been indicated by an abnormally lean correction factor P0178 Water in Fuel Sensor Voltage Too Low Flex fuel sensor input below minimum acceptble voltage P0179 Flex Fuel Sensor Volts Too High Flex fuel sensor input above maximum acceptable voltage P0182 CNG Temp Sensor Voltage Too Low Compressed natural gas temperature sensor voltage below aacceptable range P0183 CNG Temp Sensor Voltage Too High Compressed natural gas temperature sensor voltage above acceptable range P0201 (M) Injector #1 Control Circuit An open or shorted condition detected in control circuit for injector #1 or the INJ 1 injector bank P0202 (M) Injector #2 Control Circuit An open or shorted condition detected in control circuit for injector #2 or the INJ 2 injector bank P0203 (M) Injector #3 Control Circuit An open or shorted condition detected in control circuit for injector #3 or the INJ 3 injector bank P0204 (M) Injector #4 Control Circuit Injector #4 or INJ 4 injector bank output driver stage does not respond properly to the control signal P0205 (M) Injector #5 Control Circuit Injector #5 output driver stage does not respond properly to the control signal P0206 (M) Injector #6 Control Circuit Injector #6 outout driver stage does not respond properly to the control signal P0207 Injector #7 Control Circuit Injector #7 output driver stage does not respond properly to the control signal P0208 Injector #8 Control Circuit Injector #8 outout driver stage does not respond properly to the control signal P0209 Injector #9 Control Circuit Injector #9 output driver stage does not respond properly to the control signal P0210 Injector #10 Control Circuit Injector #10 output driver stage does not respond properly to the control signal P0300 (M) Multiple Cylinder Mis-fire Misfire detected in mulitple cylinders P0301 (M) Cylinder #1 Misfire Misfire detected in cylinder #1 P0302 (M) Cylinder #2 Misfire Misfire detected in cylinder #2 P0303 (M) Cylinder #3 Misfire Misfire detected in cylinder #3 P0304 (M) Cylinder #4 Misfire Misfire detected in cylinder #4 P0305 (M) Cylinder #5 Misfire Misfire detected in cylinder #5 P0306 (M) Cylinder #6 Misfire Misfire detected in cylinder #6 P0307 (M) Cylinder #7 Misfire Misfire detected in cylinder #7 P0308 (M) Cylinder #8 Misfire Misfire detected in cylinder #8 P0309 (M) Cylinder #9 Misfire Misfire detected in cylinder #9 P0310 (M) Cylinder #10 Misfire Misfire detected in cylinder #10 P0320 No Crank Reference Signal at PCM No reference signal (crankshaft position sensor) detected during engine cranking P0325 Knock Sensor #1 Circuit Knock sensor (#1) signal above or below minimum acceptable threshold voltage at particular engine speeds P0330 Knock Sensor #2 Circuit Knock sensor (#2) signal above or below minimum acceptable threshold voltage at particular engine speeds P0340 (M) No Cam Signal At PCM No fuel sync P0350 Ignition Coil Draws Too Much Current A coil (1-5) is drawing too much current P0351 (M) Ignition Coil #1 Primary Circuit Peak primary circuit current not achieved with maximum dwell time P0352 (M) Ignition Coil #2 Primary Circuit Peak primary circuit current not achieved with maximum dwell time P0353 (M) Ignition Coil #3 Primary Circuit Peak primary circuit current not achieved with maximum dwell time P0354 (M) Ignition Coil #4 Primary Circuit Peak primary circuit current not achieved with maximum dwell time P0355 (M) Ignition Coil #5 Primary Circuit Peak primary circuit current not achieved with maximum dwell time P0356 (M) Ignition Coil #6 Primary Circuit Peak primary circuit current not achieved with maximum dwell time P0357 Ignition Coil #7 Primary Circuit Peak primary circuit current not achieved with maximum dwell time P0358 Ignition Coil #8 Primary Circuit Peak primary circuit current not achieved with maximum dwell time P0401 (M) EGR System Failure Required change in air/fuel ration not detected during diagnostic test P0403 (M) EGR Solenoid Circuit An open or shorted conditon detected in the EGR solenoid control circuit P0404 (M) EGR Position Sensor Rationality EGR position sensor signal does not correlate to EGR duty cycle P0405 (M) EGR Position Sensor Volts Too Low EGR position sensor input below the acceptable voltage range P0406 (M) EGR Position Sensor Volts Too High EGR position sensor input above the acceptable voltage range P0412 Secondary Air Solenoid Circuit An open or shorted condition detected in the secondary air (air switching/aspirator) sloenoid control circuit P0420 (M) 1/1 Catalytic Converter Efficency Catalyst 1/1 efficency below required level P0432 (M) 2/1 Catalytic Converter Efficency Catalyst 2/1 efficency below required level P0441 (M) Evap Purge Flow Monitor Insufficient or excessive vapor flow detected duirng evaporative emission system operation P0442 (M) Evap Leak Monitor 0.040 Leak Detected A 0.040 leak has been detected in the evaporative system P0443 (M) Evap Purge Solenoid Circuit An open or shorted condition in the EVAP purge solenoid control circuit P0455 (M) Evap Leak Monitor Large Leak Detected A large leak has been detected in the evaporative system P0456 Evap Leak Monitor 0.020 Leak Detected A 0.020 leak has been detected in the evaporative sstem P0460 Fuel Level Unit No Change Over Miles No movement of fuel sender detected P0461 Fuel Level Unit No Changeover Time No level of fuel leel sender detected P0462 Fuel Level Sending Unit Volts Too Low Fuel level sensor input below acceptable range P0463 Fuel Level Sending Unit Volts Too High Fuel level sensor input above acceptable range P0500 (M) No Vehicle Speed Sensor Signal No vehicle speed sensor signal detected during road load conditions P0505 (M) Idle Air Control Motor Circuits Replace P0508 Idle Air Control Motor Circuit Low Idle Air Control Motor Circuit below acceptable current P0509 Idle Air Control Motor Circuit High Idle Air Control Motor Circuit above acceptable current P0522 Oil Pressure Sensor Low Oil pressure sensor input below acceptable voltage P0523 Oil Pressure Sensor High Oil pressure sensor input above acceptable voltage P0551 (M) Power Steering Switch Failure Incorrect input state detected for the power steering switch circuit. PL: High pressure seen at high speed P0600 (M) PCM Failure SPI Communications No communication detected between co-processors in the control module P0601 (M) Internal Controller Failure Internal control module fault condition (check sum) detected P0604 Internal Trans Controller Transmission control module RAM self test fault detected P0605 Internal Trans Controller Transmission control module ROM self test fault detected P0622 (G) Generator Field Not Switching Properly An open or shorted condition detected in the generator field control circuit P0645 A/C Clutch Relay Circuit An open or shorted condition detected in the A/C clutch relay control circuit P0700 (M) EATX Controller DTC Present This SBEC III or JTEC DTC indicates that the EATX or Aisin controller has an active fault and has illuminated the MIL via a CCD (EATX) or SCI (Aisin) message. The specific fault must be acquired from the EATX via CCD or from the Aisin via ISO-9141 P0703 (M) Brake Switch Stuck Pressed or Released Incorrect input state detected in the brake switch circuit (Changed from P1595) P0711 Trans Temp Sensor, No Temp Rise Relationship between the transmission and overdrive After Start operation and/or TCC operation indicates a failure or the Transmission Temperature Sensor. OBD II Rationality P0712 Trans Temp Sensor Voltage Too Low Transmission fluid temperature sensor input below acceptable voltage P0713 Trans Temp Sensor Voltage Too High Transmission fluid temperature sensor input above acceptable voltage P0720 Low Output SPD Sensor RPM The realtionship between the Output Shaft Speed Above 15 MPH Sensor and vehicle speed is not within acceptable limits P0740 (M) Torque Converter Clutch, No RPM Realtionship between engine and vehicle speeds indicated Drop at Lockup failure of torque converter clutch lock-up ssytem (TCC/PTU sol) P0743 Torque Converter Clutch/Solenoid Trans An open or shorted condition detected in the torque Relay Circuits converter clutch (part throttle unlock) solenoid control circuit. Shift solenoid circuit C electrical fault-Aisin Trans P0748 Governor Pressure Solenoid Control/Trans An open or shorted condition detected in the Governor Relay Circuits Pressure Solenoid circuit or Trans Relay Circuit in JTEC RE transmissions P0751 O/D Switch Pressed (Lo) More Than Overdrive override switch input is in a prolonged 5 Minutes depressed state P0753 Trans 3-4 Shift Solenoid/Trans Relay An open or shorted condition detected in the overdrive Circuits solenoid control circuit or Trans Relay in JTEC RE trans. P0756 AW4 Shift Solenoid B (2-3) Shift solenoid B (2-3) functional fault-Aisin transmission Functional Failure P0783 3-4 Shift Solenoid, No RPM Drop The overdrive solenoid is unable to engage the gear at Lock-up change from 3rd gear to the overdrive gear P0801 Reverse Gear Lockout Circuit Open An open or shorted condition detected in the transmission or Short reverse gear lock-out solenoid control circuit P01192 Inlet Air Temp. Circuit Low Inlet Air Temp. sensor input below acceptable voltage P01193 Inlet Air Temp. Circuit High Inlet Air Temp. sensor input above acceptable voltage P1195 (M) 1/1 O2 Sensor Slow During Catalyst A slow switching oxygen sensor has been detected in Monitor bank 1/1 during catalyst monitor test. (was P0133) P1196 (M) 2/1 O2 Sensor Slow During Catalyst A slow switching oxygen sensor has been detected in Monitor bank 2/1 during catalyst monitor test. (was P0153) P1197 1/2 O2 Sensor Slow During Catalyst A slow switching oxygen sensor has been detected in Monitor bank 1/2 during catalyst monitor test. (was P0139) P1198 Radiator Temperature Sensor Radiator coolant temperature sensor input is above Volts Too High the maximum acceptable voltage P1199 Radiator Temperature Sensor Radiator coolant temperature sensor input is below Volts Too Low the minimum acceptable voltage P1281 Engine is Running Cold Too Long Engine coolant temperature remains below normal operating temperatures during vehicle travel (Thermostat) P1282 Fuel Pump Relay Control Circuit An open or shorted condition detected in the fuel pump relay control circuit P1288 Intake Manifold Short Runner An open or shorted condition detected in the short Solenoid Circuit runner tuning valve circuit P1289 Manifold Tune Valve Solenoid Circuit An open or shorted condition detected in the manifold tuning valve solenoid control circuit P1290 CNG Fuel System Pressure Too High Compressed natural gas system pressure above normal operating range P1291 No Temp Rise Seen From Intake Energizing Heated Air Intake does not change intake air Heaters temperature sensor an acceptable amount P1292 CNG Pressure Sensor Voltage Too High Compressed natural gas pressure sensor reading above acceptable voltage P1293 CNG Pressure Sensor Voltage Too Low Compressed natural gas pressure sensor reading below acceptable voltage P1294 (M) Target Idle Not Reached Target RPM not achieved during drive idle condition Possible vacuum leak or IAC (AIS) lost steps P1295 No 5 Volts to Throttle Position Sensor Loss of 5 volt feed to the Throttle Position Sensor has been detected P1296 No 5 Volts to MAP Sensor Loss of 5 volt feed to the MAP Sensor has been detected P1297 (M) No Change in MAP From Start to Run No difference is recognized between the MAP reading at engine idle and the stored barometric pressure reading P1298 Lean Operation at Wide Open Throttle A prolonged lean condition is detected during Wide Open Throttle P1299 (M) Vacuum Leak Found (IAC Fully Seated) MAP Sensor signal does not correlate to Thorttle Position Sensor signal. Possible vacuum leak P1388 Auto Shutdown Relay Control Circuit An open or shorted condition detected in the ASD or CNG shutoff relay control cicuit P1389 No ASD Relay Output Voltage at PCM No Z1 or Z2 voltage sensed when the auto shutdown relay is energized P1390 (M) Timing Belt Skipped 1 Toot or More Relationship between Cam and Crank signals not correct P1391 (M) Intermittent Loss of CMP or CKP Loss of the Cam Position Sensor or Crank Position Sensor has occurred. For PL 2.0L P1398 (M) Mis-fire Adaptive Numerator at Limit PCM is unable to learn the Crank Sensor's signal in preparation for the mis-fire diagnostics. Probable defective Crank Sensor P1399 Wait to Start Lamp Circuit An open or shorted condition detected in the Wait to Start Lamp Circuit P1403 No 5 Volts to EGR Sensor Loss of 5 Volt feed to the EGR position sensor P1476 Too Little Secondary Air Insufficient flow of secondary air injection detcted during aspirator test (was P0411) P1477 Too Much Secondary Air Excessive flow of secondary air injection detected during aspirator test (was P0411) P1478 (M) Battery Temperature Sensor Volts Out Internal temperature sensor input voltage out of an of Limit aaceptable range P1479 Transmission Fan Relay Circuit An open or shorted condition detected in the transmission fan relay circuit P1480 PCV Solenoid Circuit An open or shorted condition detected in the PCV solenoid circuit P1482 Catalyst Temperautre Sensor Circuit Catalyst temperature sensor circuit shorted low P1483 Catalyst Temperautre Sensor Circuit Catalyst temperature sensor circuit shorted high Shorted High P1484 Catalytic Converter Overheat Detected A catalyst overheat cindition has been detected by the catalyst temperature sensor P1485 Air Injection Solenoid Circuit An open or shorted condition detected in the air assist solenoid circuit P1486 (M) EVAP Leak Monitor Pinched Hose Found LDP has detected a pinched hose in the evaporative hose system P1487 High Speed Radiator Fan Control Relay An open or shorted condition detected in the control Circuit circuit of the #2 high speed radiator fan contorl relay P1488 Auxiliary 5 Volt Supply Output too Low Auxiliary 5 Volt sensor feed is sensed to be below an acceptable limit P1489 (M) High Speed Fan Control Relay Circuit An open or shorted condition detected in the control circuit of the high speed radiator fan control relay P1490 (M) Low Speed Fan Control Relay Circuit An open or shorted condition detected in the control circuit of the low speed radiator fan control relay P1491 Radiator Fan Control Relay Circuit An open or shorted condition detected in the radiator fan control relay control circuit. This includes PWM solid state relays P1492 (M,G) Ambient/Battery Temperature Sensor External temperature sensor input above acceptable Volts Too High voltage P1493 (M,G) Ambient/Battery Temperature Sensor External temperature sensor input below acceptable Volts Too Low voltage P1494 (M) Leak Detection Pump Sw or Mechanical Incorrect input state detected for the Leak Detection Fault Pump (LDP) pressure switch P1495 (M) Leak Detection Pump Solenoid Circuit An open or shorted condition detected in the Leak Detection Pump (LDP) solenoid circuit P1496 (M) 5 Volt Supply Output Too Low 5 Volt sensor feed is sensed to be below an acceptable limit (<4v for 4 seconds) P1498 High Speed Radiator Fan Ground Control An open or shorted condition detected in the control Relay circuit circuit of the #3 high speed radiator fan control relay P1594 (G) Charging System Voltage Too High Battery voltage sense input above target charging voltage during engine operation P1595 Speed Control Solenoid Circuits An open or shorted condition detected in either or the speed control vacuum or vent solenoid control circuits P1596 Speed Control Switch Always High Speed control switch input above maximum acceptable voltage P1597 Speed Control Switch Always Low Speed control switch input below minimum acceptable voltage P1598 A/C Pressure Sensor Volts Too High A/C pressure sensor input above maximum acceptable voltage P1599 A/C Pressure Sensor Volts Too Low A/C pressure sensor input below minimum acceptable voltage P1602 PCM not Programmed P1680 Clutch Released Switch Citcuit P1681 No I/P Cluster CCD/J1850 Message No CCD/J1850 messages received from the cluster Received control module P1682 (G) Charging System Volatage Too Low Battery voltage sense input above target charging voltage during engine operation and no significant change in voltage detected during active test of generator output circuit P1683 Speed Control Power Relay: or S/C 12v An open or shorted condition detected in the speed Driver CKT control servo power control circuit. (SBEC II: ext relay) P1684 Battery Loss in the Last 50 Starts The battery has been disconnected within the last 50 starts P1685 Skim Invalid Key The engine controller has received an invalid key from the SKIM P1686 No SKIM BUS Messages Received No CCD/J1850 messages received from the Smart Key Immobilizer Module (SKIM) P1687 No MIC BUS Message No CCD/J1850 messages received from the Mechanical Instrument Cluster (MIC) module P1693 DTC Detected in Companion Module A fault has been generated in the companion engine control module P1694 Fault in Companion Module No CCD/J1850 messagea received from the powertrain control module-Aisin transmission P1695 No CCD/J1850 Message From Body No CCD/J1850 messages received from the body control Control Module module P1696 (M) PCM Failure EEPROM Write Denied Unsuccessful attempt to write to an EEPROM location by the control module P1697 (M) PCM Failure SRI Mile Not Stored Unsuccessful attempt to update Service Reminder Indicator (SRI or EMR) mileage in the control module EEPROM P1698 (M) No CCD/J1850 Message From TCM No CCD/J1850 messages received from the electronic transmission control module (EATX) or the Aisin transmission module P1719 Skip Shift Solenoid Circuit An open or shorted condition detected in the transmission 2-3 gear lockout solenoid control circuit P1756 GOV Press Not Equal To Target @ The requested pressure and the actual pressure are not 15-20 PSI within a tolerance band for the Governor Control System which is used to regulate governor pressure to control shift for 1st, 2nd,and 3rd gear (Mid Pressure Malfunction) P1757 GOV Press Not Equal To Target @ The requested pressure and the actual pressure are not 15-20 PSI within a tolerance band for the Governor Control System shift for 1st, 2nd,and 3rd gear (Zero Pressure Malfunction) P1762 GOV Press Sensor Offset Volts Too Low The Governor Pressure Sensor input is greater than a of High calibration limit or is less than a calibration limit for 3 consecutive park/neutral calibrations P1763 Governor Pressure Sensor Volts Too High The Governor Pressure Sensor input is above an acceptable voltage level P1764 Governor Pressure Sensor Volts Too Low The Governor Pressure Sensor input is below an acceptable voltage level P1765 Transmission 12 Volt Supply Relay An open or shorted condition is detected in the Control Circuit Transmission Relay control circuit. This relay supplies power to the TCC> P1899 (M) P/N Switch Stuck in Park or in Gear Incorrect input state detected for the Park/Neutral switch |
when the battery is disconnected you need to wait about 5 minutes for it to reset the computer...
