Dodge Neon / SX2.0 Halo lights installation
Hi There.
Just joined the forum. Yesterday had the halo headlights installed on my SX 2.0(Neon) 04. Now i am having an issue. Please help. I turn my car on. My halo lights, led and fog lamps turn on. My engines start and still they work fine. Now comes the problem, i turn the projector lights on and then turn them off, now as expected the fog lamps and halo lights should come up but they dont . Please help |
do you get any power from the mulitfunction switch when the headlights are on, sometimes it goes bad... not running hid projectors are you? Welcome to DF ^^
Originally Posted by TejasMtnBiker
(Post 3149290)
if it takes alot of cranking to get started there's other issues, fuel pressure, ignition, etc. even on a bad battery mine will start really fast... you can put a 12v meter on the battery turn the hids on an see how much drain it has, they usually dont pull a ton from what I see on my friends vheicles... but I see deal extreme has the kits cheap these days with good reviews
