Need Elec Part Name & Info
I have a 2005 Dodge Neon SXT, I bought if used and fund out I am missing the piece that you would plug the diagnostic tool into.. Name please?
I'm also having an issue when I am coasting, not pushing the accelerator or the brake and all my dials just stop working on my dash. The car doesn't die when this happens. When I apply either the gas or the brake, they start working again until the next time.. Any ideas? Can't afford a mechanic... |
Your missing the OBD port or you just cant find it? Normally located under the dash on the driver side. Did you not test drive it before purchasing?
Name of port, which I Received
Originally Posted by jkeaton
(Post 3260658)
The OBD port should be on the left side of the foot well on the driver's side, basically somewhere in-between the door and steering column. They are tucked up under the dash sometimes, which IIRC, the Neon one is.
As for the vacuum leak, check for a loose/worn gas cap or a cracked line coming off of the evap canister (by the rear passenger wheel). |
it's called the DLC connector
Originally Posted by boatmoter
(Post 3262515)
