Timing belt hangs off cam shaft sprocket
Old 10-06-2017, 09:21 AM
whynotme's Avatar
whynotme
whynotme is offline
Default Timing belt hangs off cam shaft sprocket
After replacing my timing belt on my 2000 neon, i rotated the crank shaft twice by hand. I notice the timing belt had moved over the cam shaft sprocket by about 1/8 inch. After repeated tries, the same thing kept happening. I am unsure as to why the belt moves. All alignment marks are in place and the timing is within the window (timing). Need help
Old 10-06-2017, 09:50 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,165 Likes on 2,919 Posts
Got a pulley on backwards?
Welcome to DF! Moving to the neon section for ya.
