need 05 neon output axle shaft #?
Old 11-13-2018, 12:48 PM
mike L's Avatar
mike L
mike L is offline
Default need 05 neon output axle shaft #?
Napa could not find the number. 05 neon 2.0 auto. 3459S timkens?
Old 11-13-2018, 12:57 PM
jkeaton is offline
Dodge Forum Administrator
Do you mean CV axle? Which side?
Old 11-14-2018, 02:22 PM
mike L's Avatar
mike L
mike L is offline
Thanks I found it.
I also have a leak from the bearing axle shaft retainer, that bolts onto the transaxle. Does the whole back side of the retainer need to be covered by a light coat of sealer?
There's a 1/2" x 1/4" hole at the bottom of the transmission that gets covered by the retainer. The last person didn't cover the whole back side with sealer ( around that bottom hole was not sealed ) I was wondering if that is why it was dripping. The axle seal is not leaking by the way.
Thanks!
Quick Reply: need 05 neon output axle shaft #?
