won't start
Have a 2000 dodge neon that will not start. Timming is ok,and have replaced the sensors on crank shaft and cam and replaced the comcuter but stii cannot get spark?How do you reset the computer.
RE: won't start
is the injecter firing and on the coil pack is there positive power it should be the green and white wire check too see if it has power if not your asd relay has gone bad
too reset the ecu just unhook the bat for 10min |
RE: won't start
the injectors are firing and put a new coil pack on. i am looking fro a shor some where .
thanks |
| All times are GMT -4. The time now is 12:01 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
