DIY-Radiator Replacement and mounting of E-Fans
Old Apr 25, 2012 | 06:37 PM
Pacmanloads's Avatar
Pacmanloads
Default DIY-Radiator Replacement and mounting of E-Fans
Well I had to replace my radiator as it was beginning to leak so I thought I would post up some pics on how my fans are mounted and maybe help someone out with a small DIY.
[IMG][/IMG]
First things First drain your coolant with the petcock on the bottom of the drivers side of the rad . Remove Cap to help vent drainage .
While this is draining remove coolant overflow and windshield washer bottles.
Next Remove shroud ( 4 bolts one in each corner )
[IMG][/IMG]
[IMG][/IMG]
Next Remove top radiator hose followed by the bottom. If you still have the factory Transmission cooler lines hooked to your Radiator you will need a disconnect tool for the lines.
Remove 2 bolts at the top of the radiator and lift it out .
Place new rad inside facing up on a flat working surface .
[IMG][/IMG]
Line up the E-Fans so that the top mounting hole lines up with the small lip at the top of the radiator.
[IMG][/IMG]
Drill a 3/16" hole on each side and thread a bolt through the fan and rad . This will take the weight of the fans .
[IMG][/IMG]
Next use zip tie kit for mounting on four points on each fan and push them between the fins of the rad , flip over and use rubber washers and plastic zip tie ends to pull and hold the fans tightly against the radiator. Cut of the remaining tie.
[IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Next just install your new Radiator following the steps in reverse . Hope this helps someone out . Cheers !
Here are the wiring instructions as well.
[IMG][/IMG]
[IMG][/IMG]
Last edited by Pacmanloads; Apr 26, 2012 at 09:57 AM. Reason: added wiring instructions
Old May 19, 2012 | 12:12 AM
QuadCabLuv's Avatar
QuadCabLuv
where can you buy those zip tie kits?
Old May 19, 2012 | 08:33 AM
Pacmanloads
The Kit I bought came with them , but when I needed to switch rads I bought replacements here .http://www.ebay.com/itm/280801544770...#ht_2419wt_825
Old Jul 20, 2012 | 03:16 PM
wjxavier's Avatar
wjxavier
what is the kit that you used? and how does it hold up?
Old Apr 16, 2013 | 11:30 PM
spun360's Avatar
spun360
heres a diff way to do it!
Attached Thumbnails DIY-Radiator Replacement and mounting of E-Fans-hpim0859.jpg
Old Dec 9, 2013 | 08:21 PM
dieselsuburban95's Avatar
dieselsuburban95
What size and cfm fans do you use I have the 5.9 gas and I would like to do this
Old Dec 9, 2013 | 08:43 PM
Spillage's Avatar
Spillage
I have two 16" 2024cfm (21.5amp each) SPAL fans on my 5.2L gas (4048cfm total).
One of these fans by itself keeps up not a problem.
I have them on a Flex-a-lite controller, so they're only running at 60% (unless that isn't enough, which it is).
Old Dec 9, 2013 | 08:49 PM
dieselsuburban95
Ok thanks I want to do this one day
