Old 11-25-2009, 09:38 PM
004x41500's Avatar
004x41500
004x41500 is offline
well i also started to eyeball a second trans cooler... also gonna be putting an ext filter, as well as trans temp gauge in...any ideas on where the best/most accurate place would be to put the sending unit?
  #2062
Old 11-25-2009, 09:53 PM
95MaroonMonster's Avatar
95MaroonMonster
95MaroonMonster is offline
drove 250 miles home, the cat delete threw another CEL, shut the truck down, refired it, no cel for the last 70 or so miles, i think i need to reset the computer
but it is doing better on fuel with the cat gone
  #2063
Old 11-25-2009, 10:03 PM
004x41500's Avatar
004x41500
how much better is it doing?
  #2064
Old 11-25-2009, 10:24 PM
95MaroonMonster
well on the 250 mile drive, i only used half a tank = a little over 14 mpg
(i made it from Kewanne Illinois to the indiana line on a quarter tank, would have done better after that but traffic got heavy
  #2065
Old 11-25-2009, 10:27 PM
004x41500's Avatar
004x41500
damn im currently geting about 250 to a full tank
  #2066
Old 11-25-2009, 10:33 PM
dakotas ram's Avatar
dakotas ram
dakotas ram is offline
miami put his on the back side of the pan i believe, to block from wind and so the fluid is pushed back there
  #2067
Old 11-25-2009, 11:24 PM
95MaroonMonster
which tank do you have, the 26 or the 35
  #2068
Old 11-25-2009, 11:33 PM
004x41500's Avatar
004x41500
26, why what do you have?
  #2069
Old 11-26-2009, 12:16 AM
95MaroonMonster
35 gallon
  #2070
Old 11-26-2009, 10:04 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Originally Posted by Oren09
Plugs in cylinders 1 & 8 had a very small amount of oil, just enough to make the threads wet. Not sure if this is indicative of anything?
see if the low side of the valve cover has any oil around the gasket. my plugs used to get a good little bit of oil on them from a bad valve cover gasket leak. it did make the plug heat shields easy to pull out though.
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
