I don't know what the difference in the two are but they look like the same rim. They came on later models and 4x4's. Anyone know if they will fit a '99 4x2? Thanks
if it's the same size or bigger than your factory wheels, the will fit !! remmember that you can go higher in size but no lower than your factory size....
Bolt pattern is the same, however, you will find you won't be able to put the front center caps on as the bearing dust cap protrudes through the wheel.
I've got 15" wagon wheels on my 98. fronts clear, rear is close...didnt even think about it when i bought them (used with 35's and a good deal)
this is true!!!!,, but the later dodge ram i think it was 2000 changed and has a diff setup which should work
