DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen RAM general discussion/NON-tech (https://dodgeforum.com/forum/2nd-gen-ram-general-discussion-non-tech-146/)
-   -   tell me if it's worth it (https://dodgeforum.com/forum/2nd-gen-ram-general-discussion-non-tech/322775-tell-me-if-its-worth-it.html)
dipsherry Apr 4, 2012 10:37 AM
creeping c-list and these have been on there for a while.....just curious if you guys would say they are worth it....to me it would be cheaper than buying a set of axles and rebuilding with locker and gears....
dipsherry Apr 4, 2012 10:38 AM
http://miami.craigslist.org/mdc/pts/2878231818.html
redneck_ram Apr 4, 2012 10:40 AM
holy expensive! i wouldnt pay that much for those, but they look nice!
Gary-L Apr 4, 2012 10:45 AM
Not unless there are a couple of high dollar hookers and some blow included.
dipsherry Apr 4, 2012 10:48 AM
yeah seemed high but i am in my axesl with gears seals and everything about $3000...so i figured i would have to pay that much again to build a set of d60's or d70's
dipsherry Apr 4, 2012 11:25 AM
http://miami.craigslist.org/brw/pts/2888817645.html
there are these but no lockers ...
merc225hp Apr 4, 2012 12:07 PM
The top ad, The front diff has a pass side pumpkin no good for you, well unless you are going to do a t case double setup, which you can then pick your drop side to which ever side you like.
Wh1t3NuKle Apr 4, 2012 12:26 PM
Originally Posted by dipsherry (Post 2756805)
Actually not bad at all considering that are built out. I'd inquire about all the paperwork.
The dana60 front appears to be low pinion though, but hard to tell. Also, I think it's a kingpin.
http://images.craigslist.org/5L15F35...6e149812c3.jpg
Appears drivers side to me?
dip, you realize there is one fabrication issue right? get dodge coil buckets integrated if you keep them, or integrate coilovers, or go leaf spring (simplest).
Edit: you'll need to know what year and what vehicle they came out of. Then you can determine if you want/need to keep your speedo working in addition to the fabrication. Lots of build threads out there that can guide you, but research will get you there to minimize the $$$ as much as possible. Driveshaft changes are an example.
merc225hp Apr 4, 2012 12:42 PM
In the pix below you can see the cast in leaf spring mount, flat side should be up, making this a pass side pumpkin. It is a Kingpin front that's for sure.
http://i962.photobucket.com/albums/a...b266c91270.jpg
Wh1t3NuKle Apr 4, 2012 12:47 PM
^Yup agreed.
Based on that detail this confirms the axle is a Kingpin HP60. Chevy?
Also appears to have been intended to use hydraulic ram assist.
© 2026 MH Sub I, LLC dba Internet Brands
