Wheeling a fullsize
Old May 12, 2014 | 12:58 AM
  #441
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by corbo1962
I measured my truck and I have 18" on the front springs and 47" on all four fender Wells. I suppose if I swapped out the cable on the winch then I might gain another inch in the front. I would say your lift is an effective 9-10" lift
So your suspension lift is 5" coil + 2" spacer = the 18" measurement from bucket to bucket using my pictures.
I have 16.5" or so and that makes my spring roughly the 5" variety then.
Thanks for the help on that estimation.
On some 7" SLs there has been a need to clock the tcase down and lengthen front driveshaft. Did you end up doing that too?
Old May 12, 2014 | 01:00 AM
  #442
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by Wombat Ranger
Carl your rig is coming along nice. Good work. Why are you still on 1/2 tons? Ha.
I am building a 35spl 9" and hp44 to go under my jeep. I will eventually have some time off work and one day when it's done I will hit you up to go run the rubicon and have a beer or 2.
Originally Posted by dlyter09
Truck is still looking amazing as it always has!! Im jealous haha
Yo, it's the two old home slices!! hahahah
Thanks guys. Running these half tons making you look bad is why there still being run. Still have the others under construction. Get that heep running and indeed will roll in there so I can recover ya!
Good to see ya guys.
Old May 12, 2014 | 01:08 AM
  #443
Wh1t3NuKle's Avatar
Wh1t3NuKle
Ran the Hell Hole trail that was mentioned a few posts back this past saturday. Here's some pics to hold over. No damage, no dings like last time, but almost a pretzeled tie rod.
The starting group, but the blue 4runner bailed early in b/c of child stuff and the red powerwagon (it was his first ever trail run) decided to park and not attempt the major obstacle.
oops
Back in
Old May 12, 2014 | 08:00 AM
  #444
corbo1962's Avatar
corbo1962
No, the drive shaft is stock and the Tcase has not been clocked. With the axle swap, the drive shaft was on the verge of being too long and with the 2"spacer everything worked out well. I guess I should look at the angle on the front shaft and evaluate the clocking issue.
Old May 12, 2014 | 02:42 PM
  #445
corbo1962's Avatar
corbo1962
On page 2 of this thread, a friend of yours put Coilovers on his 3/4 ton shortbed. What are the specific's on those, like brand, model, travel and length open/closed.
Old May 13, 2014 | 09:12 AM
  #446
Wh1t3NuKle's Avatar
Wh1t3NuKle
His is actually a converted 1500 as well. PO already had swapped the axles to 3/4T running gear, including the badging.
The shock's are Bilstein 9100 17" with remote resi. They are pretty wicked.
Here is his build thread to see more details.
http://www.pirate4x4.com/forum/dodge...een-dodge.html
Old May 13, 2014 | 04:25 PM
  #447
Thornloe Pride's Avatar
Thornloe Pride
Going on a fishing trip this weekend with a few guys and we have to wheel to the spot. It's quite the trail. Ill try and get some pics of my truck in action.
Old May 13, 2014 | 06:16 PM
  #448
corbo1962's Avatar
corbo1962
Thanks WK, I'm looking at options in getting a little more of a lift. The tires can hit when she flexes too much. Have you had any adverse effects from your body lift and how long have you had it on your truck? Do you have to tighten it up every now and then? Any high center of gravity issues? A 3" body lift would get me up to an effective 10" lift and solve the problem of the tire hitting body. I had a bad experience with a 2" body lift on a bronco II that I had some years ago.
Old May 14, 2014 | 12:50 AM
  #449
Wh1t3NuKle's Avatar
Wh1t3NuKle
I've had the BL on now for 2.5 years strong. No issues to report to date. No loosening of bolts and there is no CG concerns from my experience. Note that the green dodge on C/Os is also on a 3" BL. Cheapest form to get extra wheel uptravel. Plus give more room to work on top of the drivetrain. There are no CG issues because our truck is long and full width. On jeeps and B2 you're narrower with respect to lift height, which tends to enhance any CG effects.
Or instead of adding a BL, fab up and replace fenders with tube fenders....
Old May 15, 2014 | 10:50 PM
  #450
Wh1t3NuKle's Avatar
Wh1t3NuKle
One of the bids from last Saturday. The pitch is hard to tell and really looking forward to deeper case ratio.
Hell Hole in a Foolsize:
