What kind of lift should I get?
I own a 1998 dodge ram1500 sport. I was woundering what kind of lift I should get I wanna fit 33" tires on it But I still want a little room between the tire and the wheel well. I don't know if just this leveling kit would be good.
http://www.topguncustomz.com/p-6987-...-lift-kit.aspx
And I also didn't know what else I would have to do because its a 4.5 in lift on the front. Not would it lift the back up too? Some please give me some answers!!!!
All you need is 2.5" spacers for 33s and a level truck. That link you posted will not work by itself because once you go over 3" of lift, you need to change other components. and I dont think over 2.5-3" of lift will look right with 33s.
HBS sells good quality spacers for like $90. Thats what I have on my truck.
You won't need to lift the rear if you want your truck level. Our trucks come from the factory with 3" blocks in the rear, so adding 2.5" spacers up front level the truck out.
You don't have struts...just shocks. And replacing them isn't completely necessary, although it will ride better with longer shocks. Especially if you're offroading.
