I put heads on a 240k engine
Old 04-19-2017, 05:43 PM
LIZZRD's Avatar
LIZZRD
LIZZRD is offline
thinking on doing the change of cyl heads to EQ , timing chain , water pump etc.
Would most people use a Dodge repair manual or Chilton ?
  #22
Old 04-19-2017, 09:49 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
grab the factory service manual from this forum and use that for anything and everything. Forget the chiltons or Haynes. Also the internet is a wealth kf knowledge for DIYs.
Originally Posted by 1997JollyGreenGiant
So what are your plans? You going to rebuild your short block?
someday..... I hope to do something similar to what Frankie did. i.e. a 408.....
.......but perhaps also just build a high compression 360.
  #23
Old 04-22-2017, 10:11 AM
LIZZRD's Avatar
LIZZRD
LIZZRD is offline
Would somebody point me into the right direction for that
1997- service manual , found others here but not what i need... thanks
  #24
Old 04-22-2017, 11:59 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
Here. I think it is actually the 96 manual, but, it should be darn close for your truck.
  #25
Old 04-23-2017, 01:24 PM
LIZZRD's Avatar
LIZZRD
LIZZRD is offline
thank you for your help ...
  #26
Old 06-09-2019, 09:10 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Truck still runs like a top. 250k miles. Still burns oil. Still geared like a tractor. Body starting to get a little rough. Steering still sloppy.
The following users liked this post:
2bit (08-03-2019)
  #27
Old 06-10-2019, 11:23 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
1997JollyGreenGiant is offline
Thanks for the update! Was wondering how your truck was doing with the heads. Plan on replacing mine soon.
Quick Reply: I put heads on a 240k engine
