DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   Truck won't start HELP! (https://dodgeforum.com/forum/2nd-gen-ram-tech/100428-truck-wont-start-help.html)
timesublime Apr 1, 2007 09:26 PM
1997 2500 4x4 5.9 gas 5spd 8800 GVWR
Replaced fuel pump, spark plugs, checked ignition coil resistance. The engine turns over and you can smell gas out the tail pipe, I pulled a plug and it was sparking. Pulled the codes and came up with p0351 "Ignition Coil A primary/secondary Malfunction. The resistance was in the listed ranges both primary and secondary 1.1 and 13000 ohms respectivly. Truly stumped and frustrated. Any ideas?
dhvaughan Apr 2, 2007 02:50 AM
RE: Truck won't start HELP!
if it was me i would replace the coil. about $50.
i'm also wondering if it has jumped time, or has a bad crank or cam sensor ??
when did it run last and what did it do when it quit ?
timesublime Apr 2, 2007 03:12 AM
I'm thinking new cap/rotor at this point. Last run 5 days ago. MSD coil. Classic run then stop, not start again. Any recs, on cap and rotors?
mooseyy40 Apr 6, 2007 10:58 PM
Replace cap & rotor and see if it does it. if not it may be crank position sensor located on back of block. I had same problem as you but replaced sensor first, didnt work then cap & rotor replaced and it ran.
© 2026 MH Sub I, LLC dba Internet Brands
