DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   Could somebody please help me? my instrument cluster's gone all crazy. (https://dodgeforum.com/forum/2nd-gen-ram-tech/106971-could-somebody-please-help-me-my-instrument-clusters-gone-all-crazy.html)
fryerdiesel May 19, 2007 08:28 PM
Anybody seen this before? Dash lights up like a Christmas tree. Check engine, ABS, air bag, low fuel, check guages, brake, etc. lights all come on, all guages drop to 0, mileage odometer disappears and and in it's place a message, "No Bus" comes up. I know it's a communication problem of some sort but was just wondering if this is a common problem that somone else has seen and fixed or if I have a lot of diagnosis ahead of me. Thanks.
dhvaughan May 20, 2007 04:00 PM
RE: Could somebody please help me? my instrument cluster's gone all crazy.
mine did that when i forgot to put on the 2-3 ground wires at the power steering pump. there are also a group of grounds behind drivers side kickpanel. maybe some on firewall near pcm. also clean the ground cable at battery. i've also heard of it doing this with a blown fuse (check end of dash and pdc box under hood). also check that all wires and plugs are tight at pcm.
whiteram00 May 20, 2007 07:34 PM
had a problem like that with my dakota a while back an it was a lose ground behind the cluster cause when it happend i could smakc the top of the dash an it would come on,so i checked an fixed it
© 2026 MH Sub I, LLC dba Internet Brands
