Can't get my differential housing out!
Well 'm in the middle of a posi install and I cannot get the rear differential out of my Indy. It comes so far out then just stops at a certain point.
RE: Can't get my differential housing out!
Any help? I have the carrier bearing caps off and have been prying at it forever , the axles and everything are out it just doesn't make sense.
To tell you the truth I never took the 9.25 apart. I have had this experiance on an older1 ton Full Floating axle before, but since you have a semi floating c clip axle I dunno it it'll be the same. Worth a shot though.
Under the bearing caps there are the two other pieces which need to be "screwed out". They sit right on the outside of the bearing and adjust preload. Here is a pic of the axle I did it on, the things I'm talking about are right there this guy is pointing. The thing with the holes all around it, they're on both sides. http://img.photobucket.com/albums/v2...ard/collar.jpg If the 9.25 has this mark is so you can put it back to the same spot. Then stick a screw driver in one of the holes and give it a wack to loosen it up. Keep loosening it until you can get the carrier out. You have to do it to both sides. Keep track of how many times you spun it around too. I'm prety sure the 9.25 doesn't have this though... |
Thanks , they have something similar so I am going to try that tomorrow.
Thanks again. |
| All times are GMT -4. The time now is 06:37 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
