True Duals with Straight Pipes Video
RE: True Duals with Straight Pipes Video
ORIGINAL: IndyRamMan
super 44s would be the win.
with the true dual, the super 44's will sound a lot "chirpier", but it will be very loud and sound great. With the si/do super 44 system, it will sound a little more basier and consistent and equally loud, and less chirpier. I know this for sure because my bro ran a true dual with the super 44's, and i run a si/do super 44 system at the moment. i think u should keep the true dual though, you did all that work from the manifolds back, you should use it!
ORIGINAL: 20DodgeNeon00
ORIGINAL: Cereal Killer
Yeah, you definetly don't want to go from true duals back to a SI/DO. That's a step backwards.
Ironically not the pat most people change. Most people change their exaust from the cat back. That's pretty much wothless except for the sound. Might buy you a couple horses. Getting headers and runnng true duals or a 3in Y-pipe on the other hand can give you some pretty significant gains. and since you'd have to replace the cats for that, the highflow puts the icing on the cake.
Is exhaust over rated... Yes
Is it also a very important decision... Yes
I think you should throw two of those Super 44 mufflers into that true dual. When I say chirpier I don't mean in a bad way, it's still very deep and loud. With true duals, you just have so much air pumping through the system that it makes this extra noise, remember when I showed you that video of my brothers f350 with the super 44 true dual? As he passed it made that kind of chripy chamber noise? Here it is again, it doesnt sound bad at all, it's quite awesome!
Here's the vid (keep in mind that was just a queer camera phone, in real life, it was super loud!!
http://youtube.com/watch?v=XUX8eeQUsdY
I know for a fact that when I do my exhaust I am going to go with magnaflow, only because I know they are a tad quieter and I want to be a bit different from the croud, plus nobody can deny the fact that magnaflow does have a nice distinct sound.
It will be this, Pacetter LT's, 3" Y-Pipe, to magnaflow high flow cat, to single inlet/dual outlet magnaflow muffler, then exit behind both rear tires.
