Great Link for Speed/ RPM Calculations
I found a link which is great for looking up your speed or rpm calculations. I know, it's a (gulp) GM F-body website. But, it has a pull down menu of pre-programmed vehicle transmissions included Jeep &Dodge trucks. I figure it can't be that bad if they list our trucks on there.
Here are the Dodge/Jeep transmissions it has programmed: NV4500 5-speed NV4600 6-speed 45RFE 5-speed G56 6-speed AISIN 6-speed Auto Throw in your tire size and axle ratio in the appropriate box and it does the rest. http://www.f-body.org/gears/ |
RE: Great Link for Speed/ RPM Calculations
Here is one that shows many Dodge Truck gear ratios for the individual transmission gears.
http://www.gearvendors.com/d2wd4s.html |
ORIGINAL: w9awx I found a link which is great for looking up your speed or rpm calculations. I know, it's a (gulp) GM F-body website. But, it has a pull down menu of pre-programmed vehicle transmissions included Jeep &Dodge trucks. I figure it can't be that bad if they list our trucks on there. Here are the Dodge/Jeep transmissions it has programmed: NV4500 5-speed NV4600 6-speed 45RFE 5-speed G56 6-speed AISIN 6-speed Auto Throw in your tire size and axle ratio in the appropriate box and it does the rest. |
I had added it but must have not copied correctly. Edited with link.
