Mopar Junk!
Mopar Junk!
OK, calm down
I'm just pissed off. My very expensive Mopar Performance headers have rusted through.
Both sides!
The chrome mostly peeled off a while back and they been looking pretty ratty for a while. That I could live with but now the noise severely irritates me.
There were a few pin holes that I patched with some muffler cement a while back that worked pretty good but now were beyond that kind of fix again. I knew I was on borrowed time.
So I've been looking for some budget replacement readers.
Some of the eBay stuff looks not bad. Anyone have any experience with any of those no name stainless systems?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...tab%3DWatching
http://cgi.ebay.ca/ws/eBayISAPI.dll?...:IT&ih=002
AND there another hitch I just remembered The Mopar headers use a different down pipe . I had to chop off the stock ones at the Cat and weld on special flange mount pipes. Old ones went in the trash with the stock manifolds long ago...
This could get expensive. I really don't want to replace the Cat, it only maybe 2 years old
CRAP!
Both sides!
CRAP!
RE: Mopar Junk!
ORIGINAL: xskylinedx
+1 Find a welder (unless you can weld yourself), pull 'em off, get a patched welded, and if you cant/won't get them coated you could paint them with high heat paint.
ORIGINAL: IndyRamMan
No way to patch it with some plate and get it coated?
RE: Mopar Junk!
you can't really weld or braze much when the metal is paper thin, rusting through, and there's no real structural point to tie back to. you end up just making a bigger hole. jmo, but i've been through headers before, and decided they are a monumental pita and waste of money. they do look cool for a year or so, and then rust away into junk. too bad nobody makes a solid cast iron header type manifold that lasts (or do they). hell, they'd cost a fortune...
this will sound stupid but you might just mix up a whole package of jb-weld and put it all the way in and around the whole thing. couldn't hurt to try. i made and entire muffler like that for my 4-wheeler. it took 4 packs of jb and i used 2 coats.
Trending Topics
RE: Mopar Junk!
ORIGINAL: dhvaughan
In that case, if you have a small hole, try getting some heat shield, wrap it TIGHT arround that primary. Then take either an exhaust clamp or header wrap and keep that heat shield on there tight. Definately not the best solution, but cheeper than 400 for new ones.
