318'S I WANT MORE HP OUT OF MY 318
Old Feb 10, 2008 | 03:34 PM
  #21
IndyRamMan's Avatar
IndyRamMan
Default RE: 318'S I WANT MORE HP OUT OF MY 318
ORIGINAL: Rampant 150
Damn straight. Pick up this book- how to build big-inch mopar small-blocks, just search for it on google. It tells you exactly what you need to do. Its the book that I am basing my 390 on if I ever get around to it.
Thats actually a really good book for beginers. It matches up a lot of good parts to make some good power, as well as blueprints diffrent parts for diffrent objectives (mpg, low end tq, mid range daily driver, drag race screamer, etc.) Unfortunately most of the parts are mopar performance parts that they use in that book. nothing wrong with them, im just never a fan of using manufacturer's aftermarket parts totaly
Old Feb 6, 2011 | 11:23 AM
  #22
1999blkdakrt's Avatar
1999blkdakrt
Originally Posted by IndyRamMan
A motor is a motor...318 and 360s are identical except for displacement, and also a diffrent sized throttle body. Anything you see for a 360 you can use for a 318
For your information these engines are not identical, they have different crank journals, thus making the block different, its just not a bore and crank difference. Also the throttle bodies are identical in every way, shape and form. Same part number. Must have had the info mixed up between the 2.
Old Feb 6, 2011 | 12:04 PM
  #23
redneck_ram's Avatar
redneck_ram
uh guy i think you are about 3 years too late on this post. check out the dates...
Old Feb 6, 2011 | 12:18 PM
  #24
Silver_Dodge's Avatar
Silver_Dodge
If I recall correctly, the throttle bodys are different. Most 5.2's stock TBs are 50mm coned down to 48mm or so. On most 360's, the stock TB is 52mm coned down to something I can't recall at the moment.
Old Feb 6, 2011 | 02:12 PM
  #25
pcfixerpro's Avatar
pcfixerpro
They are the same silver. 50mm -> 48mm
Old Feb 6, 2011 | 02:14 PM
  #26
Silver_Dodge
Hmm, ok. My bad.
Old Feb 7, 2011 | 07:30 AM
  #27
1999blkdakrt
My bad I didn't realize that the thread was that old, nevertheless sometimes it is good to revive a old thread for the sake of accuracy.
Old Feb 7, 2011 | 09:19 AM
  #28
jasonw's Avatar
jasonw
Site Moderator
Yup, 5.2L and 5.9L throttle bodies are the same, 50mm tapered down to 48mm or so. Thats why when you bore it out (or have someone like Dan the Fastman bore it out for you) to 52mm for a 5.9L, you have to have new throttle plates.
