Any of you guys replaced your interior lights with LED'S??
Old Mar 9, 2008 | 02:39 PM
Racinfan83's Avatar
Racinfan83
Default Any of you guys replaced your interior lights with LED'S??
We replaced the interior map lights, domelights, glovebox light, etc.in our 300C with LED'S. They put out a LOT more light and look cool as well. Have any of you done this in your Rams, and if so, can you give me the part numbers of the LED lights you used and where you got them? Thanks.....
Old Mar 9, 2008 | 03:01 PM
jasonw's Avatar
jasonw
Site Moderator
Default RE: Any of you guys replaced your interior lights with LED'S??
The LEDs usually have the same part numbers as the regular bulbs, just LED.
As far as what numbers you need, this is taken from Sylvania's website and their automotive bulb replacement guide.
2001 DODGE Ram Pickup (With 2 headlamp system)
High & low beam headlamp
9004
Parking light
3157
Front turn signal
3157
Rear turn signal
3157
Tail light
3157
Stop light
3157
High mount stop light
921
Fog/Driving light
896
License plate
168
Back up light
3157
Front sidemarker
3157
Rear sidemarker
194
Ash tray
161
Glove box
1891
Dome light
579
Step/Courtesy light
194
Trunk/Cargo area
921
Under hood light
561
Instrument-general
158
PC194
PC74
Check engine indicator
PC74
Hi-beam indicator
PC194
Seat belt indicator
PC74
Brake warning
PC194
Automatic transmission indicator
PC74
Directional signal indicator
PC194
Ignition switch
1445
Old Mar 9, 2008 | 05:53 PM
98DodgeRam1500's Avatar
98DodgeRam1500
Thats the one issue I have with my Ram.
All lights are not bright.The headlights and fog lights aren't as bright as I would like them. Going clear will "clear" up the issue.
The interior lights aren't bright either. My wifes pacifica and my golf's lights are 2x brighter. I might try going LED on the inside, I just don't want to get blinded if i turn them on while driving.
Old Mar 9, 2008 | 07:01 PM
jasonw's Avatar
jasonw
Site Moderator
The only way LEDs are usually that blinding are if you look directly into them and they are pointing directly at you. If there is any sort of angle at all, you won't be blinded.
I would go eBay for LEDs. I always have, and as long as you're careful about who you buy them from (look at feedback ratings), you should be able to get good deals. Another thing to watch out for, like always with eBay, is shipping costs. Some of them will greatly overcharge for shipping.
Old Mar 9, 2008 | 07:06 PM
Racinfan83's Avatar
Racinfan83
There is a good website for led's autolumination.com - but the website gives me a headache trying to figure out what's what on there. My truck is in the shop til Tues, so I guess I'll see what bulbs are in there when I get it back and try to match them up to led's.....
Old Mar 10, 2008 | 03:20 AM
Chopper1's Avatar
Chopper1
One of my cars has a lot of them changed out. Works great. The floor board lights are wired to old wire and stuck through the original light holder. The dash lights such as the fog lamp and mirror control panel lights have LED's siliconed in the light holes. Works good and the lighting color can be changed by the new lights.
