DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   cruise control doesn't work (https://dodgeforum.com/forum/2nd-gen-ram-tech/156226-cruise-control-doesnt-work.html)
ben2080 Apr 6, 2008 04:49 PM
My cruise controlwon'tstay on. When you turn it on it turns off like 2 sec. later. Sometimes i push the button and it won't even turn on. I don't even have time to see if it will hold the speed. It kinda seems like an electrical problem to me but i don't even know where to start looking. Thanks for any suggestions
rabbler Apr 6, 2008 04:53 PM
RE: cruise control doesn't work
Probably a bad clock spring.
Does your horn work?
ben2080 Apr 6, 2008 05:24 PM
yeah, the horn works.
RallyDogRacing Apr 6, 2008 08:15 PM
You might try holding your toe under the brake pedal to ensure that it stays in the upmost position to ensure that your brake-light switch isn't getting falsely activated and killing cruise. When it dies does the green-light on the steering wheel control also go out?
ben2080 Apr 6, 2008 08:56 PM
I haven't noticed it at all. It might not even turn on.
V10 Jim Apr 7, 2008 01:16 PM
My cruise has a simular problem. I found a solution by accident. After pushing the set button I gently manipulate the accel button and the cruise stays set at the speed that I pushed the set button in the first place. Don't know what is actually is causing the problem but at least the cruise is working. I'm a big cruise fan. Hope this helps.
© 2026 MH Sub I, LLC dba Internet Brands
