DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   In case you haven't been told... (https://dodgeforum.com/forum/2nd-gen-ram-tech/160600-in-case-you-havent-been-told.html)
priest1981 May 5, 2008 09:45 PM
So, I was driving through my neighborhood with the windows down the other day and I heard an odd noise from the left front wheel. When I got home I found that I had two broken wheel lugs and the other three nuts were loose. I replaced the studs and nuts and all is well, thank GOD that I found it before the wheel fell off (especially with my wife and kids in it). I just wanted to know if anyone else has had this happen? I do go out wheelingand was wondering if that would cause the nuts to loosen up. My truck is a 98 Q.C. 1500 4X4 with LT265/75 R16 tires.
The moral of the story is check your lug nuts for proper torque.
Will
[IMG]local://upfiles/57732/C048B1C0A7D6438CA6FEE357F047B548.jpg[/IMG]
padodgeram May 5, 2008 09:57 PM
RE: In case you haven't been told...
who was the last person to take the wheel off ?? And NO this does not happen all the time , butttt check the torque at least once a month and i go with 100 lbs of TQ...
priest1981 May 5, 2008 09:57 PM
Another picture.
[IMG]local://upfiles/57732/DA6E9D276A404256A2117EA1D27A5251.jpg[/IMG]
priest1981 May 5, 2008 10:02 PM
ORIGINAL: padodgeram
I was, I used the cheap shop impact and torque sticks andnot my good Matco stuff[sm=oopssign.gif]
Will
padodgeram May 5, 2008 10:07 PM
ORIGINAL: priest1981
Will
at least every thing work out...lesson learned....
greg_glider May 6, 2008 12:51 AM
every time i take my wheels off, I always tighten the wheel lug nuts as much as I can before I put the wheels down , then when the wheels are on the ground, I check the wheel lug nuts to 100ftlbs. After I ride around for a bit, I recheck the lugnut torque again. sometimes they loosen a bit but not too much. Never had a problem with the lugnuts loosening.
priest1981 May 6, 2008 01:51 PM
[/quote]
[/quote]
Exactly, lesson learned and the only casualty was Andrew Jackson!
Will
EricCartman May 6, 2008 05:17 PM
I did a similar thing before... and ever since then I have always re-tightend with a torque wrench. It takes a few more minutes, but it gives you a chance to work on your guns :Dand gives you a piece of mind knowing that everything is on good.
I even tell the tires shop to hand torque everything when I take it in.
Glad everything worked out alright..
Cartman
© 2026 MH Sub I, LLC dba Internet Brands
