Wierd ABS Brake Behavior, Won't stay Broke!
Old May 8, 2008 | 07:34 PM
dhvaughan's Avatar
dhvaughan
Default RE: Wierd ABS Brake Behavior, Need Help!
ORIGINAL: Muddy Creek Sam
Would this cause the brakes to be almost none existant and not pump up?
Sam [sm=helpout.gif]
poor, soft, or spongy brakes that won't pump up would lead me to replace the master cylinder.
Old May 9, 2008 | 07:59 PM
Muddy Creek Sam's Avatar
Muddy Creek Sam
Default RE: Wierd ABS Brake Behavior, Won't stay Broke!
Master Cylinder and Power unit test OK as per Factory Service Manual. Still broke one time works the next. Dam Pita.[:@]
Sam
Old May 9, 2008 | 09:02 PM
BigVanLittleWoman's Avatar
BigVanLittleWoman
Junior Member
I had this very thing happening right now!
I slammed on my brakes this morning in the rain to avoid hitting an idiot.
All day my brakes have been making that "grind" of the ABS noise on and off. The lights for both Brake and ABS are on after I start to move.
I took the kids out to dinner and drove home 15 miles per hour having everyone pass me on a two lane road!!! I didn't want to go any faster and not be able to stop.
Yes, when I left the restaurant I pushed the brakes and got the abs grind and stiff peddle with NO stopping power at all. Then as I pull into our street, 1 mile down the road, I brake into our driveway fine.
I checked the fluid, it was between full and add, it was hot. I can't remember if you check brake fluid hot or cold. It might need fluid, but that isn't the reason for the above behavior.
Every stinking time I take it to the dealership for something, something else goes wrong.
1) Feb took it in for the recall on the ignition, the "resistor pack" for the a/c fan speed goes
2) Finally take it in to have the resistor pack installed last week b/c I can't get to it with simple tools, like they told me -- and now the brakes!
I swear the dealership is the cause.
Old May 12, 2008 | 10:28 PM
Muddy Creek Sam
btt
