DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   need help rpm's jumping (https://dodgeforum.com/forum/2nd-gen-ram-tech/168133-need-help-rpms-jumping.html)
milkdud110 Jul 10, 2008 01:10 PM
when i am going at a steady speed the rpm's jump. like if i am going 55mph the rpm's will jump likefrom 1500 too 2000rpm. it doesnt do it all the time but it dont act like thetranny is sliping or any thing like that. what do i check or do? i called a tranny shop and theysaid all they can do is drive it around and see if they can change diffrent parts to see if it is a frequence thats making it do it. i dont know thats what they said like changing the alt and the battery and so forth. and they want to charge me 300 just to look at it.
if any one has a idea please let me know what to look at
again. the RPM'S jump when at a steady speed like if you pushed the gas when going 55 and hit the brake. please help me i can not fiqure it out!!!1
THANK YOU
dhvaughan Jul 10, 2008 10:54 PM
RE: need help rpm's jumping
does it feel like the transmission is shifting ?
it could be shifting out of overdrive and then back in. this'd be about a 500 rpm change.
or it could be unlocking the torque converter and relocking in. this'd be about a 300 rpm change.
i'd think you could feel the shift...
faulty throttle position sensor (tps) on drivers side of throttle body can cause excessive overdrive shifting. fairly cheap around $40-50 and 5 minutes to change.
hometheaterman Jul 11, 2008 12:16 AM
Mine did this and it was a bad TPS. I replaced it and it went away. I'd check that first if not it might be the torque converter is bad but honestly this is exactly the symptoms a bad TPS seems to cause or at least it did for me so I'd try that.
They are super easy to change. They are on the side of the throttle body. They are torx bolts I think holding it in so you'd need either a torx socket or screwdriver. You just unclip the plug on it and take those two bolts out and it comes off then bolt the new one in and plug the wiring back up.
Mudbone25 Jul 11, 2008 12:17 AM
+1 TPS. Try cleaning it first. Theres a diy on it.
milkdud110 Jul 11, 2008 03:04 PM
i bought a new one. And put it on thursday havent drove anywhere to see if it worked. thanks for the info i will let you know if it worked i hope it did.
SilverRam_01 Jul 11, 2008 04:45 PM
mine was the same. it was the tps. i found out using a digital multi meter that it was only making .68 volts, so i drilled the holes out, and adjusted it, and now its making .75 and it works great.
© 2026 MH Sub I, LLC dba Internet Brands
