Codes
Finally got a code reader and this is what it said:
P0740 TCC circuit malfunction P0751 Shift solenoid A CKT performance or stuck off P1756 Gov press not equal to target not 15-20 PSI Do these have to do with my transmission slipping and not shifting past 2nd gear? |
RE: Codes
I would say yes...
From the 2001 FSM: P0740 -> Relationship between engine and vehicle speeds indicated failure of torque convertor clutch lock-up system (TCC/PTU solenoid) P0751 -> Overdrive override switch input is in a prolonged depressed state. Overdrive Off switch input too low for more than 5 minutes (4-speed auto. trans. only). P1756 ->The requested pressure and the actual pressure are not within a tolerance band for the Governor Control System which is used to regulate governor pressure to control shifts for 1st, 2nd, and 3rd gear. (Mid Pressure Malfunction) Cartman |
