What sensor's to clean?
Truck has been idling a little ruff and im just bored so what sensor's should i clean?
PCV valve, entire throttle body, run some seafoam through it (if you use the brake booster line pour it in "too slowly" so you dont screw up anything), don't know if you can clean map sensors
iac.. i believe
Got the iac cleaned idle's smoother now could do much more since it started to rain. Thanks
| All times are GMT -4. The time now is 04:56 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
