will a 35" tire fit...
1 Attachment(s)
Will a 35x12.50x17 fit on these 17" wheels? Im currently running a 315/70/17 BFG with zero problems.
Anyone have any pics? Attachment 114693 |
LT315/70R17/D 121R BSW 54142 8.5 - 10 12 on 8.5 34.5 17 601 3195@50 GM
Above is the specs for those tires...they say they are 34.5 so 35 should fit with no problems. My only concern would be the width...Have a lift? Is so a 3 inch should clear them just fine. I have no lift and I run 33 with no rubbing unless I hit a rock while turning. |
When you run a 315/70/17 through the tire size converter it comes out to a 34.4x12.4 tire. So to awnser your question you already have a 35x 12.5, it's going to fit and look the same as what you got lol.
I have a 2" leveling kit on the front. I knew the height was the same but i didnt know of the width.
Main reason why I asked is because a 35/12.5/17 is a lot more common to find than a 315/70/17. Thanks for the help guys. Mark |
